It is currently Fri Jul 18, 2025 3:11 am
PostPosted: Sun Nov 03, 2013 10:00 pm
First name: Stuart
Last Name: Gort
I still have to get photos taken for June...which is a small body, semi-hollow I have finished and playing.
This is Molly - The Machine ... a 24 fret neck-through made with manufacturing methods that will hopefully impart as much of the .0003" repeatability spec of my cnc machine into the instrument. The idea is....
1. To mount the guitar on the machine as few times as possible.
2. To make as many cuts as possible in one "holding" that define the string track and playability (outside fretboard edges, fretboard surface, fret positions, pickup cavity placement, nut placement, tuner holes, bridge placement...ect.)
3. To hold the guitar rigidly...but without tension during the machining operations.
Tooling is everything and I came up with some unique ways of holding things. The final cut that defines the fretboard surface is made with no stress on the neck...after it's glued to the guitar.
Also designed a new bridge system for this one...essentially a tune-o-matic concept but it mounts and adjusts in a manner similar to the pickups.
Molly will have black anodized hardware with silver trim, black Gotoh tuners, and Lace Drop & Gain pups.
StuMusic
 Post subject: Re: Molly - The Machine
PostPosted: Sun Nov 03, 2013 11:46 pm
Intriguing.
PostPosted: Mon Nov 04, 2013 10:05 am
I like the shape. Will it be chambered t all?
Wisdom is justified by her children
PostPosted: Mon Nov 04, 2013 10:43 am
First name: Stuart
Last Name: Gort
Thanks....yes on the chambering.
Look closely at the gray lines on the side body panels...you can see the supporting rails inside.
The side body panels are nearly hollow except for the supporting rails.
StuMusic
PostPosted: Mon Nov 04, 2013 3:18 pm
State: AR
Man I'm looking forware to seeing that completed.
I'm guessing it's not a carve top and no neck or head angle. ?
I can imagine a real stealth type carved top for that.
PostPosted: Mon Nov 04, 2013 3:47 pm
First name: Stuart
Last Name: Gort
It's quite carved actually...that angle won't show it off but it definitely has a 3D shape. :)
The head angle is flat as you observed.
StuMusic
PostPosted: Mon Nov 04, 2013 7:12 pm
State: AR
Well I think it's a great design but what
is amazing is the degree of accuracy you are achieving...and
repeatable-Ace.
Thanks for sharing Stuart.
PostPosted: Mon Nov 04, 2013 8:27 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I got a thing for weird shaped guitars. I love it!
Brian
PostPosted: Tue Nov 05, 2013 9:55 am
First name: Rand
Last Name: Kennedy
State: CO
Very ambitious but you've got the skills... I hope you are creating something magical.
PostPosted: Wed Nov 06, 2013 7:17 pm
First name: D
Last Name: S
I like it Stuart!
wah
Wah-wah-wah-wah
Wah
PostPosted: Wed Nov 06, 2013 10:23 pm
Pretty cool Stuart. Please post progress pics as you move along.
PostPosted: Thu Nov 07, 2013 6:37 am
Stuart,
I usually don't comment on electrics, but the shape of this design seems esthetically near perfect to my eye. I will look forward to seeing the actual build.
Congrats,
Max
Max Bishop
Brighton, Michigan
PostPosted: Thu Nov 07, 2013 12:07 pm
First name: Stuart
Last Name: Gort
Thanks guys...that shape motivated a series of new ideas. Odd how that works.
Sandywood...the accuracy described is common to big, production cnc's. I should note that with previous guitars I haven't exploited that accuracy thoroughly due to the way I conceived the building process. This new method is big departure from the previous method. I have to make all new tooling to make this one. Truly, it's going to take about three times more work to make the tooling than the guitar itself.
StuMusic
PostPosted: Thu Nov 07, 2013 1:11 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I really like your design. I do wonder if you are intentionally making a rather current drug reference with the name.
PostPosted: Thu Nov 07, 2013 4:01 pm
First name: Stuart
Last Name: Gort
Lol...that's NOT it, John. :)
When my wife I and were deciding names for our kids...the girls would have been Elise (her middle name), June, or Molly. We had two boys.
My first guitar model is Elise, second June...and so on.
Wait til the fourth design...if I name her MaryJane, Crystal, or Skag...then you'll know.
StuMusic
PostPosted: Sun Nov 17, 2013 3:50 pm
First name: Stuart
Last Name: Gort
I'm not making headstock facings on Molly...and due the less than 100% success rate of these logos (I'm getting a tiny chip in one out of ten or twenty) I decided to make a little medallion that will simply drop into a recess on the headstock. When I was putting this logo into a headstock facing I had the luxury of actually throwing away the whole facing if it wasn't perfect.
I'm not willing to throw a whole guitar away on account of a chipped logo... :)
StuMusic
PostPosted: Sun Nov 17, 2013 5:50 pm
First name: D
Last Name: S
These are insanely cool!
The shadows really make the logo pop.
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Mar 06, 2014 12:00 pm
First name: Stuart
Last Name: Gort
Just getting this photo of Molly's hardware into this thread. I'm using links to this thread here and there as I promote the guitar online.
StuMusic
PostPosted: Thu Mar 06, 2014 7:55 pm
Stuart, your work is top notch!
Old growth, shmold growth!
PostPosted: Fri Mar 07, 2014 10:41 am
State: AR
It's a great idea.
When I was looking, since I didn't have a laser, I found http://www.woodcraft.com/Product/2080066/25302/WoodRiver-Personalized-Laser-Engraved-Insert-Template.aspx
which were to big but they did work great for the custom guitar cases.
PostPosted: Sun Mar 09, 2014 2:50 pm
First name: Stuart
Last Name: Gort
Thanks GW and SW.
The tooling and neck blocks are complete. Here are Molly's guts.
These panels will be glued each to their counterparts and then glued to the center block to make the basic shape to be carved. This is the prototype of my first neck-through design which will allow various body and headstock shapes and varied scale lengths (up to bass scales) all using the same tooling fixtures.
This new tooling technique should result in an instrument with a playing weight in the range of 6.5 to 7.0 pounds.
StuMusic
